New cobalt point motors with inbuilt decoders
antonyjq
Post by antonyjq » Sun Nov 16, 2014 12:23 pm
Hi all.
Was hoping to get a few ideas / thoughts from you on the new cobalt point motors (with inbuilt decoder).
Am toying with the idea of using these in the future.
One "issue" springs to mind: have of you got any thoughts on the use of an accessory bus with the new cobalt?
I use an accessory bus that drives my turnouts / signals which is entirely separate from my track bus. If using the new cobalts to power the frog, the feed to the frog will be from the accessory bus rather than a track bus.
If a loco overruns a point, it would, presumably then short both the track bus (through the stock rail) and also the accessory bus (through) the frog. Uhmm...
Any ideas?
Ant
Re: New cobalt point motors with inbuilt decoders
Post by Mike_R » Wed Nov 19, 2014 7:22 pm
The description of the motor says it has two SPDT switches same as the non-digital ones, so no problem with frog powering. Power the frog switch with track power and the motor with accessory bus power.
