Permanente Local
Permanente Local
Post by BrianMoore » Fri Aug 01, 2014 7:12 pm
https://www.youtube.com/watch?v=UzdnOXSuUx0
A few days ago, Rob Mallett and I had a lot of fun creating an accurate rendition of Southern Pacific's Permanente Local.
Thanks for looking.
Re: Permanente Local
Post by torikoos » Mon Aug 04, 2014 4:58 pm
I love seeing Geeps in a consist, with accurate sounds.
The only problem with sound in a small room is that it doesn't fade away well enough, and our video cameras pick up everything, but I'm a sound convert, I'd rather have sound than no sound, and there are volume settings you can adjust to make them a little quieter. I usually set them such that the sound of the loco is just a bit louder than the sound of the drive and motor of the model at the usual speeds. At higher speeds the drives tend to take over a bit in my case, but I rarely exceed 20 scale mph on my home layout.
Next thing for me surely will be some freight car noises to try out.
