Sticking it down!
Are you handlaid, sectional or flexible? Raise your questions or give us your tips here...
Sticking it down!
Post by Mike_R » Sat Feb 02, 2013 8:45 pm
I've read about the different adhesives to stick track down with, none of which seem to be easily available here. Up until now I've spiked track down.
Today I wanted to make a test bit of track for experimenting with staining my sand based ballast, what to stick it with?
I always have a tube of no-nails type adhesive (I use the cheaper store branded ones) in a cartridge gun, so I tried it. Putting a very thin layer on some hardboard and pressing the track in, it held straight away. I put ballast and thinned PVA on half an hour later, track stayed put.
I've some track laying on a module to do soon, I'll use this method again. The adhesive lasts for ages so long as a cap is put on the nozzle, I use it for scenery, filling, foam and some wood joins, so another use is a bonus.
I normally use PVA for the trackbed, I'm now thinking this adhesive would be a lot faster.
Re: Sticking it down!
Post by torikoos » Sun Feb 03, 2013 10:02 am
It IS a lot faster, I've used it for my modules too. And so far all seems good. However I think using some PC ties etc at module ends is still a good idea.
Post by Mike_R » Sun Feb 03, 2013 2:40 pm
I always have the rails soldered to PC ties or brass screws at all baseboard joins. I prefer screws as they are a lot stronger, but harder to disguise. On my logging layout I bent Z shapes from nickel silver sheet, the rails were soldered to the top of the Z (only the width of the rail base) and the bottom was a lot longer with a screw hole drilled for fixing to the baseboard. This is almost invisible once ballasted.
I also make the track bed under the end from solid pine strip to further strengthen the fixing.
