Kaley Yard
trevorsmith3489
Kaley Yard
Post by trevorsmith3489 » Wed Oct 31, 2012 11:14 pm
Re: Kaley Yard
Post by BrianMoore » Thu Nov 01, 2012 12:09 pm
Simply wonderful.
trevorsmith3489
Re: Kaley Yard
Post by trevorsmith3489 » Fri Jun 07, 2013 11:36 pm
At last, some progress with Kaley Yard!
http://kaleyyard.wordpress.com/2013/06/ ... -2nd-2013/
Re: Kaley Yard
Post by Gloriousnse » Sat Jun 08, 2013 7:12 am
Fab scenery, looks superb!
Re: Kaley Yard
Post by Mike_R » Sat Jun 08, 2013 1:34 pm
Looking good!
I haven't heard of using Pledge for ballast, I have a bottle to use for puddles and a clear coat over paint, but had not thought of using for glue.
Do you dilute it? Does it look glossy afterwards?
trevorsmith3489
Re: Kaley Yard
Post by trevorsmith3489 » Sat Jun 08, 2013 5:49 pm
Hi Mike
I apply the Pledge neat with the nozzle of the small bottle seen in the photographs. I do not pre-wet the ballast before applying, it wicks along the ballast very easily. The Pledge is not clear, its a murky cream colour, but it has not changed the colour or tone of the ballast and the ballast is not shiney, just the surface of the ties where the Pledge has strayed. I scrape the shiney Pledge off the offending ties with a small flat bladed screwdriver.
Trevor
Re: Kaley Yard
Post by Mike_R » Sat Jun 08, 2013 7:15 pm
Thanks Trevor.
I'll have to try Pledge, saves straining PVA which I've had to do to stop lumps being applied.
Sounds like it soaks in better as well, another problem with PVA even with washing up liquid.
On track paint, I have been using Montana markers, from the London Graphic Centre. http://www.londongraphics.co.uk/product ... /20/page/1
I find Gravel followed by a light coat of either Brown Light or Brown looks most like modern rails. Just Brown Light for lightly use rusty tracks or Brown for yard tracks. I cut a flat on one side of the tip to get it into the rail web better.
I use the markers for car and truck weathering as well painting buildings. 2mm tips are best for rail and walls, 0.7 for details such as window frames. They dry very matt, unless you over paint a gloss coat when they come out semi gloss.
trevorsmith3489
Re: Kaley Yard
Post by trevorsmith3489 » Wed Jun 12, 2013 10:48 pm
Scratch-built signals - some proper modelling as a break from scenery!
http://kaleyyard.wordpress.com/2013/06/ ... 11th-2013/
Re: Kaley Yard
Post by Mike_R » Tue Jul 23, 2013 8:13 pm
Having tried Pledge for fixing ballast I'm a convert. One other advantage is it dries far quicker than PVA, to the extent that last weekend at our meeting I was doing some track work, added ballast and it was dry when the board was turned over about six hours later, with the last application around four hours before. Along with no need to dilute and easy soaking in, far better than PVA.
trevorsmith3489
Re: Kaley Yard
Post by trevorsmith3489 » Mon Sep 16, 2013 10:49 pm
More progress on Kaley Yard - both June 30th and July 7th posts are new today.
Re: Kaley Yard
Post by torikoos » Tue Sep 17, 2013 9:09 am
it looks great, indeed Pele Soeborg's influence is very apparent, and that's not being critical. :-)
Re: Kaley Yard
Post by BrianMoore » Tue Sep 17, 2013 10:38 am
Magnificent stuff, Trevor, and an inspiration to all.
Re: Kaley Yard
Post by Mike_R » Tue Sep 17, 2013 4:01 pm
I like the foam rocks. My preferred method is carve them with an old freezer knife and a box cutter, coat with ceiling paint and then stain.
My boulders are also from foam, I break bits off until they are the right size. Then remove thin edges and sand them rounder if naturally worn, or leave them sharp if quarried. I again coat with ceiling paint once stuck down and stain.
My new corner module has them on its causeway. I"m waiting for the ballast to dry after using Trevor's floor polish method, before the next round of scenery.
What a great idea for making grass tufts.
trevorsmith3489
Re: Kaley Yard
Post by trevorsmith3489 » Mon Oct 14, 2013 9:56 pm
More progress - roads, mountains and a cell tower disguised as a palm tree!
Re: Kaley Yard
Post by torikoos » Mon Oct 14, 2013 10:24 pm
Nice work Trevor. And your roads look great too!
