Hello Eddie
I've not had this problem with my own BLI Mikado, but it does sound similar to one I've had with the Bachmann 2-10-2s. With these, the return crank works its way out of the centre driver and then everything ends up as you've described.
With the 2-10-2s, the fix is pretty straightforward. Unscrew the keeper plate (I think the BLI locos have a similar design), set it aside, and then lift the individual wheelsets out of their bearing slots, get them back into quarter with respect to each other, then lower them back into place. With most N steam locos, some of the wheelsets are connected to the coupling rods, and some are just geared to each other. The ones that aren't connected to the rods will still have a moulding of the balance weight on, so it will look better if these are properly aligned as well. Hopefully, the individual wheelsets will still be in quarter, but if not these will need adjustment.
Once you've got everything straight, with the coupling rods all level and offset by ninety degrees from the position on the other side, the keeper plate can be screwed back on. Now, assuming the return crank retaining pin is loose or slipping, you can address the connecting rod and the return crank. To stop it working loose again, remove it (if it's not already fallen out) and add a small amount of epoxy into the hole in the driving wheel. Position the connecting and return cranks and press the pin home again. With the coupling rods at bottom dead center, the crank should lean forward very slightly. Assuming five minute epoxy, I gave my locos a very gentle test run in both forward and reverse to make sure nothing was binding, then allowed the glue to set.
The initial problem was caused by a slight splitting of the plastic in the main driver where the crank pin fits, allowing it to work loose. If the mishap with the BLI loco is due to some other cause, the crank pin may go in firmly enough not to need epoxy.
Hope this is some help.
Mikado problems
Return to “Loco & Rolling Stock”
Jump to
- Information
- ↳ Forum Info, Rules, Help
- ↳ Events - Upcoming
- ↳ Events - Past
- Competitions and Challenges
- ↳ Competitions & Challenges
- Modelling Topics
- ↳ Layout Design
- ↳ Industry Inspirations
- ↳ Track
- ↳ Electricals
- ↳ DCC Topics
- ↳ Analogue wiring
- ↳ Buildings and Scenery
- ↳ Loco & Rolling Stock
- ↳ Painting, Decalling and Weathering
- ↳ My Layout
- ↳ Operations
- ↳ Modular Topics
- ↳ General modelling topics
- Special Interest Groups
- ↳ OPSIG
- ↳ LDSIG
- ↳ HO MODSIG
- ↳ 1/48 Narrow Gauge SIG
- ↳ Narrow Gauge SIG
- ↳ Logging SIG
- ↳ N scale MODSIG
- NMRA Achievement Program
- ↳ Master Builder Motive Power
- ↳ Master Builder Cars
- ↳ Master Builder Structures
- ↳ Master Builder Scenery
- ↳ Master Builder Prototype Models
- ↳ Model Railroad Engineer-Civil
- ↳ Model Railroad Engineer-Electrical
- ↳ Chief Dispatcher
- ↳ Association Official
- ↳ Association Volunteer
- ↳ Model Railroad Author
- ↳ Achievement Program Golden Spike Award
- Prototype Rails
- ↳ Places to Visit
- ↳ Modern Rails - Freight railroads
- ↳ Modern Rails - Passenger, Commuter and Light Rail
- ↳ Fallen Flags
- ↳ Railroad Media
- ↳ Other Prototype Discussion
