Continental Modeller - Latest Issue
david_heath899
Post by david_heath899 » Sun Aug 18, 2019 10:33 am
I’ve decided it’s probably best to have a ‘Continental Modeller – Latest Issue’ thread (which can be updated ongoing) rather than create a new thread for each new issue.
Anyway, the September 2019 issue is now available and contains a couple of features that may be of interest to NMRABR members:
CLEARWATER HARBOR
Steve Waterfield describes his American On30 layout, which features a working quayside ore tippler, as having evolved rather than being designed.
MOHAWK LOOPS II
Peter Brackenbury describes his new American N layout, which evolved from the original to give the opportunity of running even longer trains at exhibitions. The layout is based on an imaginary BNSF/UP joint line in the Front Range of the Rockies.
https://peco-uk.com/pages/continental-modeller#CM-2
David Heath
david_heath899
Re: Continental Modeller - Latest Issue
Post by david_heath899 » Fri Sep 20, 2019 7:51 pm
The October 2019 issue is now available and contains a couple of features that may be of interest to NMRABR members:
HILLS COUNTRY
Patrick Grace relates how his large Colorado-inspired N gauge layout, which was originally designed with exhibiting in mind, has been developed over quite a long time.
PONTS MILL, VERMONT
Andrew Knights introduces his latest exhibition layout, a small American N gauge switching scene, once again set in his favourite part of the country.
David Heath
