bent axle
800197
bent axle
Post by 800197 » Fri Oct 28, 2016 8:00 pm
My atlas n engine has somehow developed a bent axle which makes the running wobbly. Can the truck assembly be dismantled? Any ideas appreciated. Thanks.
Re: bent axle
Post by torikoos » Sat Nov 05, 2016 1:48 pm
Hello mr ?
Do you mind elaborating which Atlas N engine it is? a photo or more detailed description will go a long way :-)
I'm sure anything can be dismantled, often a service sheet is included in the original box, which may have an 'exploded view' included, which should go some way in figuring out how it comes apart.
Kind regards,
077256
Re: bent axle
Post by 077256 » Sat Nov 05, 2016 4:55 pm
Also, if you do not have a service sheet, you may be able to download one from the Atlas website..
Dave..
800197
Re: bent axle
Post by 800197 » Sun Nov 06, 2016 4:57 pm
Hello torikoos.Thanks for your reply. The N gauge engine 5490 is a B30 with AAR-B truck assembly.I have an exploded service sheet but still cannot work out how to get to the axle. My wife took some photos(i'm computer hopeless!!) but could not send through the forum. DJ
Re: bent axle
Post by torikoos » Sun Nov 06, 2016 5:19 pm
Hello DJ,
The forum doesn't allow to upload pictures as we don't have server space big enough. However you can embed pictures. For that you upload pictures to an image hosting site such as Flickr (this is often free to sign up for) and then use links to 'embed' the picture in your post.
For help on how to do that, here's a link to our tutorial page : viewtopic.php?f=36&t=37
Kind regards,
800197
Re: bent axle
Post by 800197 » Sun Nov 06, 2016 6:18 pm
Hello again. Trying hard to send you some photos. We' not done this before. Thanks for your help. DJ
https://www.flickr.com/photos/148799050 ... res/6m105y
Hopefully
Re: bent axle
Post by torikoos » Mon Nov 07, 2016 4:10 pm
Almost there :-) The link works.
Because it is not my account I guess I don't have the correct access priviledges.
Anyway if you use the link and go to one of the pictures and look at it full screen, in the bottom right you have the option to download the photo. Next to it you find a little arrow, this is for 'sharing'.
For you this arrow should be white, not grey. If it's grey, then it's probably your privacy/sharing settings for flickr.
In any case, clicking on the arrow should then give you a little dialog, select bbcode from the little menu and the complete text (code) should be highlighted in the center below. Copy that, and paste it in your message here on the forum, just as you've done with the link.
It should then embed your picture in the post.
In anycase thanks for the link. Can you also make a picture of the bottom of the truck? just to see if we can discover any clips (I'm not an N scale modeler myself, but there may be several here on our forum who are and know exactly what to do).
Many thanks, Koos
800197
Re: bent axle
Post by 800197 » Tue Nov 22, 2016 1:14 pm
Hello(better late than never) Yesterday I typed 'atlas n gauge GP 38 bogie repair' and hey presto it came up with 'images for bogie repair' and after scrolling there was a picture of what I wanted. magic!!!! A friend has the bogies at present so will try repair when it is returned. Anyeay thanks for your help. Beat wishes, GDJ
