Paper Mills
This part of the forum is intended to be a place to log all those interesting industries we find whilst exploring courtesy of Google and Bing.
Please keep each type of industry in its own thread so folk find them easily.
If there isn't a thread for the industry you find, please create a new thread.
Paper Mills
Post by Gloriousnse »
One of the guys in our group is considering modelling this paper mill at Kimberly WI (Kimberly as in Kimberly-Clark) but more recently run by a company called NewPage I believe. (Also previously Stora Enso and Interlake Papers, it's changed hands a few times!)
Nicely for modelling purposes (especially for modules) it has two distinct 'LDE's, an unloading facility for inbound loads in tanks and covered hoppers (Imerys Pigments & Additives) plus the plant itself which in terms of the railroad is almost an end-on building flat!
Bing location: http://binged.it/175leQr
https://maps.google.co.uk/maps?q=Waukes ... .2,,0,6.84
Unfortunately if you zoom in on the Google ones it shows the plants demolition in full swing - albeit still a rail-served industry with the rubble going out by rail! Interestingly the inbound section is still in use, wonder if it works as a 'transload' for other plants in the area...?
I believe it used either recycled or 'pulp' paper brought in as a base, as there's no sign of it using chips or pulpwood. The mill closed a couple of years back unfortunately, but lasted long enough to be switched by CN taking over from Wisconsin Central, here's some cool CN power switching...
http://www.rrpicturearchives.net/showPi ... id=3234139
There's a nice set of images of the actual mill building from the railroad side here:
http://wc2scale.org/zenphoto/wc-industr ... berly-sub/
And some of the kaolin inbound bit (referred to as Imerys Pigments and Additives (ex ECC?)
Some more from the same site - both parts are featured in several pics 2/3rds of the way down here - the Imerys site has been reworked several times over the years, the newest version (2007+) seems to be arranged to be switched with a trackmobile rather than the switcher as in the above image with the CN SD40-2W
http://wc2scale.org/zenphoto/wc-industr ... es-photos/
Re: Paper Mills
Just down the river a short way is another mill (there were once loads in the area) at a place called Combined Locks - this one is referred to as 'Appleton Coated' - Appleton appear to produce paper with specialist coatings...
On Google:
https://maps.google.co.uk/maps?um=1&hl= ... a=N&tab=il
On Bing:
http://binged.it/1214vtV
Some prototype pics:
http://wc2scale.org/zenphoto/wc-industr ... erly-sub-/
Things I like with this - the way the 'main line' visits one end of the site, then wanders off into the woods for a bit before appearing back at the other end - almost two modules again, or both sides of a 'roundy' layout?
Re: Paper Mills
Post by BrianMoore »
Building a Paper Mill complex:
http://issuu.com/mr-hobbyist/docs/mrh12 ... mode=embed
Paul Dolkos' previous layout also featured a sizeable paper mill, and the article was in the April 2000 MR. I strongly recommend anyone interested in modeelling paper mills to look at it.
redbull
Re: Paper Mills
Post by redbull »
That is a 3-part series in MRH Magazine - April, May & June. Very informative
Peter Borcherds
Rochelle Intermodal N Scale Modular Layout
http://www.rochelleintermodal.com
