11th Avenue
Re: 11th Avenue
Post by Mike_R » Thu Jan 01, 2015 11:38 pm
They are all installed now, the last three took one hour (wiring was already in). They worked while the board was clamped to the Workmate. Then when back on the supports and connected to the layout, the rear, hardest one to reach on that board (it has to be that one!) would not reliably stay in position, not a motor fault but my linkage and micro switch (no slack on these leads either!), 2 #**#! hours later it was working. Murphy's law strikes again!
The other rearmost one, even harder to reach, which drives through one of the bridge girders, the turnout is on the bridge, is a bit slow so I may have to redo that one. The rest are Ok after several hours of operating.
Re: 11th Avenue
Post by Mike_R » Sun Jul 12, 2015 5:51 pm
Cloudy weather may not be good for going out in but it does give some interesting lighting on my layout.
Re: 11th Avenue
Post by PeterBowen » Fri Nov 13, 2015 8:31 pm
Conrad Motors
Where can I buy these from?
D&RGW RR
Re: 11th Avenue
Post by Mike_R » Fri Nov 13, 2015 9:12 pm
PeterBowen wrote:Conrad Motors
Unfortunately they are no longer made, typical, you find a source of reasonably priced switch motors and they stop producing them a few months later. I may try servos for future layouts.
Until the Conrads I used Fulgurex, between Conrad and Tortoise for price, but a bit noisy. They have proved reliable and have good auxiliary switches and can move both turnouts in a crossover with one motor.
catweasel
Re: 11th Avenue
Post by catweasel » Tue Nov 17, 2015 3:52 am
I've started using servo's myself. The controller I'm using is a Megapoints job,http://loolee.org/megapoints/index.html, which will control up to 12. A DCC module is also available for it. The servo's themselves are cheap Tower Hobbies micro's as they don't have to work hard. Mounts I get through MERG, which are laser cut alloy and come with 2 micro switches for frog and signals if required,along with all screws. The Controllers are very easy to use. Just connect the signal leads, apply a 9 volt supply, such as a battery pack, and the points are centred.Then connect the servo's, adjust the throw and you're done. Full details are on the Megapoints website. I'm just a very satisfied customer.
I used to be indecisive,but now I'm not sure.
Re: 11th Avenue
Post by Mike_R » Tue Nov 17, 2015 11:50 am
Interesting set of products, the bounce would look good on crossing gates. If you use semaphores, well, watch the video!
Re: 11th Avenue
Post by PeterBowen » Mon Nov 23, 2015 8:07 pm
Henry,
Many thanks for the heads up on the Megapoints and Tower Hobbies which servos are you using?
D&RGW RR
Fire station
Post by Mike_R » Thu Nov 30, 2017 9:52 pm
After a long time another building finished. For years my fire station was as bought a Walthers ready built. I have painted the exterior, detailed the interior and added lighting.
Before
Image11th Avenue vehicles by Mike Ruby, on Flickr
After
ImageFire station 11th avenue by Mike Ruby, on Flickr
Users browsing this forum: Bing [Bot] and 1 guest
