Single Track Module Set
Working from a prototype location or trying to fit a specific space? Everyone loves a good trackplan...
JimD17
Post by JimD17 » Fri Mar 28, 2014 9:30 pm
I am planning to build a 6m long set of single track N Gauge modules as a scenic run; these will have the track at the ends at the middle of the boards, as per FreemoN standards.
I have a few ideas as to the scenery I wish to do but was wondering as to what others would do. Single track only, add a spur to an industry, bridges over river or road, fixed period or generic, what?
Jim Dickinson
Re: Single Track Module Set
Post by BrianMoore » Sat Mar 29, 2014 1:18 pm
All I can add is that I eventually plan to do a single-track "spacer" module in HO, and mine will depict a city street running scene, with lots of buildings made from DPM packs (some semi-flat), and probably a grade crossing. An expanded version of Andy Gautrey's Grunge Street. http://www.rmweb.co.uk/community/index. ... -crossing/
But then, yours will be a lot longer than mine. On that length, perhaps I'd go for a "less is more" concept, and just have the whole lot as sandy scrub, for the pleasure of just running a train through it.
Post by torikoos » Mon Mar 31, 2014 6:54 am
6m in N scale is similar to 12m (40ft +) in HO , while a single track with just scenery sounds tempting, a few items for scenic interest could be included. Culverts, a bridge, an abandoned spur , some slight hill sides , trees and brushes , a grade crossing or overpass along the way etc. it would keep the viewers interest longer than a salt flat for example ...
Post by Gloriousnse » Mon Mar 31, 2014 11:14 am
Got to say that's a loooooong bit of plain track. You could conceivably have an awful lot of such features in that length without it looking contrived!
Like the grade crossing example, it'd give you enough plain track either side to have a working one without the detection getting too complicated.
Post by PeterLJ » Mon Mar 31, 2014 11:45 am
I am with Koos on this one, nothing beats a long train on a very long scenic only module! There must be a proper word for this.
Post by Mike_R » Mon Mar 31, 2014 9:42 pm
I would put in a long wide curve or two. To look good there needs to be a reason for the curve, a rock outcrop, river etc. or a cheaply built route following contours.
